Brushless Drive
ArduMower Brushless Drive
Coming soon, information about the 2021 announces new Brushless Drive for the ArduMower.
Why brushless and what are the advantages?
The disadvantage is, a brushless motor and his driver are much more expensive than a brushed DC motor. But if you see the total cost over ArduMower live time, you will see an overall cost reduction, especially for large lawn area. The cost advantage will take place after 2-4 years (depends on loan area and mower usage), by end of life of the brushes and commutator of an DC Motor.
DC motor drive : small loan area, less working hours of the ArduMower per week.
Brushless drive: large loan areas and 5-7 days / week usage of the ArduMower. Longer working hours per battery charging cycle.
400
