Brushless Drive
ArduMower Brushless Drive
Coming soon, information about the 2021 announces new Brushless Drive for the ArduMower.
Why brushless and what are the advantages?
The disadvantage is, a brushless motor and his driver are much more expensive than a brushed DC motor. But if you see the total cost over ArduMower live time, you will see an overall cost reduction, especially for large lawn area. The cost advantage will take place after 2-4 years (depends on loan area and mower usage), by end of life of the brushes and commutator of an DC Motor, where you have to replace the DC Motor by a new one. So for high usage on large areas, you will amortize the higher invest within 2 or 3 years and save a lot of money.
DC motor drive : small loan area, less working hours of the ArduMower per week.
Brushless drive: large loan areas and 5-7 days / week usage of the ArduMower. Longer working period per battery charging cycle.
400
