DIY Brushless Driver Board
Description
Before you start the assembling of the Driver Board, we will build the programmer. To build your own programmer for the controller DRV8308, you need an Arduino Nano and a 5 pin JST-XH plug with cramped wires. Solder the wires as shown in the picture and ready is the programmer hardware.
Connector Pinout
Building the PCB and connect the cable
Step 1 Soldering :
Okay, you are an expert, you do not need an Instruction how to solder some parts on a PCb. Lets go to step 2
Step 2 Connect the Brushless Motor :
Step 3 Connect the Power :
Also easy for you, connect the power cable, but switch the power off before! Please take care that you have the right polarity! The +24V power to the connector marked + and the ground pole toe the connector marked - . Check it twice! If you do it wrong, the 3.5A fuse on the board will blow up and you have to change it.
