DIY Brushless Driver Board
Version vom 3. März 2021, 10:05 Uhr von BerndS (Diskussion | Beiträge) (→‎Building the Programmer and connect the cable)
Description
Before you start the assembling of the Driver Board, we will build the programmer. To build your own programmer for the controller DRV8308, you need an Arduino Nano and a 5 pin JST-XH plug with cramped wires. Solder the wires as shown in the picture and ready is the programmer hardware. Download the Nano program, you can finde here, and load it on the Arduino Nano. Let the Arduino Sketch programm open, we need it later.
Connector Pinout
Prepare BL Driver Board and connect the cable
Step 1 Soldering :
Okay, you are an expert, you do not need an Instruction how to solder some parts on a PCB. Lets go to step 2
Step 2 Connect the Brushless Motor : Have a look into the motors datasheet and identify the motor coils U,V & W wires and connect them to the board connector. Also identify the HAL sensors for coil U,V & W and connect them to the HAL board connector as well.
Step 3 Connect the Power :
