IMU
Version vom 12. September 2014, 11:45 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Calibration abstract)
IMU module GY-80
  • Compass sensor: HMC5883L
  • Gyro: L3G4200D
This one-time calibration ensures that: -All 3 axes measurements of the acceleration sensor are weighted equally. This calibration can be performed even outside of the robot. -Cable, metal, etc. which is located in the robot near the IMU module has no effect on the compass data.
Why is it needed? A measured value (x, y, z) of a 3D compass points (as seen by his origin 0,0,0) always in one direction: to the north pole. If you rotate the 3D compass around all of its axes, all measured values ​​lie on a sphere:
Hard ircon (e.g. magnets): the sphere moves Soft ircon (e.g. metal): the sphere deforms (becomes an Ellipsoid)
Example measurements
Calibration (v0.9.3)
2.1. After calibration, each of the 6 sides of the module has to look up-side and down-side (rotated 180 °). The module has 6 sides, so it must be rotated 6 times, so that each side once is on the table (you can hold the module with your hand without moving it). Press ENTER after each calibration step. The aim of the calibration to determine the acceleration due to gravity (more precisely, the minimum / maximum value) for each axis . The module must not be artificially accelerated. The order of the sides does not matter.
1. Download ArduMag calibration app for Android. 2. If not done yet, pair your Android device with the Bluetooth module: On the Android device main screen, choose symbol "Settings" (via Android menu). Now choose "Wirless and Networks->Bluetooth Settings" and "Find device". Finally, choose "pair with this device" and enter your pin (very often "1234"). The Bluetooth module should now appear as "paired". 3. In the ArduMag app, press the Android menu key and then "Bluetooth" to connect with your Bluetooth module (and your robot). The robot should confirm the connection with a beep. The number of measurements should increase.
The order of the axis of rotation and the direction does not matter. For example, rotate each side 180 degree clockwise and then again 180 degree counterclockwise (result is a 360 degree rotation). The measurements may not fit a sphere. Examples:
Finally, press 'Calibrate' to finish the calibration. The robot will confirm the calibration with two beeps. The measurements should fit a sphere now. Examples:
Calibration (SVN version)
Jede der 6 Seiten des Moduls einmal exakt hochkant hinstellen, nicht bewegen und den Punkt zur Kalibrierung der nächsten Seite auswählen:
  • In der seriellen Konsole "IMU acc calibration next side" oder
  • In der pfodApp "Settings->IMU->acc calibration next side"
Während der Messung einer Seite das Modul nicht bewegen! Die Messung wird begleitet von einem kurzen Ton.
Diesen Schritt für alle 6 Seiten wiederholen. Wenn alle 6 Seiten kalibriert wurden, ertönt ein kurze Melodie.
Modul außer Reichweite von magnetischen oder eisenhaltigen Quellen bringen! Kompaß-Kalibrierung starten:
  • In der seriellen Konsole "IMU com calibration start/stop" oder
  • In der pfodApp "Settings->IMU->com calibration start/stop"
Jede der 6 Seiten des Moduls einmal Richtung Norden halten und das Modul solange kippen bis sich das Minimum und Maximum der Achsen nicht mehr ändert (kein Ton mehr ausgegeben wird):
Calibration test
Zum Testen der Kalibrierung Modul (Bauteilseite nach oben) mit einer Seite gegen eine Tischkante halten und nicht bewegen. Den Yaw-Wert notieren (Beispiel: -95,45). Dann das Modul um 180 Grad drehen und wieder gegen die Tischkante halten. Jetzt sollte der Yaw-Wert um 180 Grad entfernt liegen (Beispiel: -95,45 + 180 = 84,55). Diesen Test mit den beiden anderen Seiten des Moduls ebenfalls durchführen.
... Modul mit einer Seite gegen Tischkante gehalten ...
calls=30    yaw=-95.56    pitch=0.02    roll=2.52    com=-95.91    com180=84.09    gyroZ=0.00
calls=30    yaw=-95.48    pitch=-0.11    roll=2.33    com=-95.81    com180=84.19    gyroZ=-0.01
calls=30    yaw=-95.42    pitch=0.03    roll=2.42    com=-95.65    com180=84.35    gyroZ=-0.00
calls=30    yaw=-95.45    pitch=-0.21    roll=2.38    com=-95.35    com180=84.65    gyroZ=-0.00
... Modul mit derselben Seite um 180 Grad gedreht gegen Tischkante gehalten...
calls=30    yaw=85.06    pitch=-2.50    roll=0.04    com=84.91    com180=-95.09    gyroZ=-0.03
calls=30    yaw=84.90    pitch=-2.59    roll=0.05    com=84.63    com180=-95.37    gyroZ=-0.02
calls=30    yaw=85.19    pitch=-2.55    roll=0.01    com=84.73    com180=-95.27    gyroZ=-0.01
calls=30    yaw=84.98    pitch=-2.73    roll=0.02    com=84.85    com180=-95.15    gyroZ=-0.01
Falls die Abweichung mehr als ein Grad beträgt, Kalibrierung von Beschleunigungssensor und Kompaß erneut durchführen!
Man kann sich die Ergebnisse des IMU-Moduls (Yaw, Pitch, Roll) auch mit der pfodApp plotten lassen:
