Perimeter wire
Version vom 23. November 2014, 15:21 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Sender current control)
So, here's the sender:
Functional test
Receiver
Principle:
'Arduino sound sensor'
LM386 amplifier
Functional test
Choice for coil
Arrangement of coils
Layout of the wire
  1. Perimeter stop test
  2. Perimeter tracking test
While crossing the perimeter loop, something interesting happens: the signal changes its polarity, that means negative and positive voltages reverse each other. By using this principle, crossing the perimeter wire as well as the current state (robot is inside/outside) can be detected. As with perimeter v1, we will again use a motor driver to amplify the signal and an operational amplifier to amplify the received signal. The perimeter sender outputs a digital code (aka 'pseudo-noise' code), and the receiver will detect that code using a software-based digital matched filter. Depending on wheter the match result peak is positive or negative, the robot is inside or outside of the perimeter wire.
Principle:
Simulation
You can see how it works:
sender circuit:
               |---------o-- GND
               |---------o-- Arduino +5V
You can find the optimum current like this: In the Arduino software, first set IMAX pot to zero (0), and place robot in the center of the garden. Now, slowly increase IMAX pot, until 'sig' in the pfodApp plot ("Plot->Perimeter") increases (wait 10 seconds). Where 'sig' reaches its maximum, keep IMAX pot setting.
Sender automatic standby
Sender software
  • Define if you have connected a potentiometer for current control: #define USE_POT
  • Define if you have connected a charging current sensor for automatic sender standby: #define USE_CHG_CURRENT
Receiver
For receiving the signal, we use a coil (100 mH) in upright position (centered at front in robot), connected through a capacitor (4.7nF) to an LM386 operational amplifier (to amplify the received signal). When using the LM386 module, capacitor C3 on the LM386 module should be bypassed (will give a VCC/2 offset required for Arduino) and the coil should be connected to "IN" and "GND" (don't forget the shown capacitor). The LM386 output pin should be connected to an analog Arduino pin ('pinPerimeterLeft').
receiver circuit:
ADC calibration
Diagnostics
sig:  coil signal
mag:  filter result: inside (negative) or outside (positive), strengh: distance to perimeter wire - this is used for perimeter tracking
  1. Perimeter2 demo
  2. 120m perimeter wire test
