DIY Brushless Driver Board
Description
Brushless Drive Test Software
- define Reg00
- define Reg0B
A parameter discrition you will finde in the DRV8308 Datasheet[2], at page 37-40.
Attention, before you burn the double check that you have changed the speed control from SPI (default in the program) to PWM!
Reg0.JPG If you will burn the one time memory, you must change the #define Burn_Enl false //true parameter to true. Then the Nano is able to burn the parameter. Type "B" & Enter to burn the parameter and a "Y" after you hafe read the waring "Write OTP memory? It can programed only once!" and then press Enter
Connector Pinout
Step 1 Soldering :
Okay, you are an expert, you do not need an Instruction how to solder some parts on a PCB. Lets go to step 2
Step 2 Connect the Brushless Motor : Have a look into the motors datasheet and identify the motor coils U,V & W wires and connect them to the board connector. Also identify the HAL sensors for coil U,V & W and connect them to the HAL board connector as well.
Step 3 Connect the Power :
