DIY Brushless Driver Board
Version vom 4. August 2021, 10:24 Uhr von BerndS (Diskussion | Beiträge) (→‎Build BL Driver Board and connect the cable)
PCB1.x with Brushless Driver(Pic. by Uwe)
 Brushless Drive [2]
 Brushless Adapter [3]
Description
Brushless Drive Test Software
  1. define Reg00
  1. define Reg0B
A parameter discrition you will finde in the DRV8308 Datasheet[4], at page 37-40.
Connector Pinout
HAL Sensor:
clamp + : 5V Power out for HAL sensoric (ACT Motor HAL cable : red )
clamp - : GND for for HAL sensoric (ACT Motor HAL cable : black )
clamp U : HAL sensor U (ACT Motor HAL thin cable : yellow )
clamp V : HAL sensor V (ACT Motor HAL thin cable : green )
clamp W : HAL sensor W (ACT Motor HAL thin cable : blue )
Motor Coils:
clamp U : coil U (ACT Motor HAL thick cable : yellow )
clamp V : coil V (ACT Motor HAL thick cable : green )
clamp W : coil W (ACT Motor HAL thick cable : blue )
Step 1 Soldering :
Step 2 Connect the Brushless Motor : == Attetion: == Do NOT cut the motor coil cable! Specially for the blade motors, with no gear. The cable resistor and the inductivity of the cable helps to reduce the energy of the free spinning motor and protects the driver board. Have a look into the motors datasheet and identify the motor coils U,V & W wires and connect them to the board connector. Also identify the HAL sensors for coil U,V & W and connect them to the HAL board connector as well.
Step 3 Connect the Power :
3D-printed PCB holder
Bug fix
220nF at each odometry input
Fuse on PCB1.4, wire going up, over the fuse before they turn down
