PCB 1.2 (English)
This page describes how to assemble the Ardumower PCB and how to add the modules.
Required parts for the Ardumower
Overview
What is needed for building your Ardumower:
Needed modules
  • PCB dimensions 241x114mm
  • Uses the Arduino Mega 2560
PCB building manual
PCB building videos
PCB jumpers
Feature used YES NO Comment
D7: DIODE
D3: DIODE
C1, C4, U4, RV1: used
D7: SHORT-CIRCUIT
D3: SHORT-CIRCUIT
C1, C4, U4, RV1: not used
JP7: OPEN
D4: DIODE
C5: not used
JP6: OPEN
JP7: CLOSE
D4: SHORT-CIRCUIT
C5: used
JP5: OPEN
JP4: OPEN
JP5: CLOSE
Bluetooth VCC=3.3V JP8: OPEN
JP9: CLOSE
JP8: CLOSE
JP9: OPEN
Many latest modules use 3.3V
PCB modules
PCB connectors
P4 reserved Yes
P6 Lawn sensor Yes
P7 Status LEDs Yes
P8 Odometry right Yes
P9 Odometry left Yes
P10 GPS (GY-NEO6MV2) Yes
P20 Button (Start/Stop) No
P21 Drop sensor right Yes
P22 Reserved Yes
P23 Reserved Yes
P24 Reserved Yes
P25 Reserved Yes
P26 Reserved Yes
P27 Reserved Yes
P28 Reserved Yes
P29 Reserved Yes
P30 Perimeter coil right Yes
P31 Drop sensor left Yes
P32 GND Yes
P33 5V Yes
P34 3.3V Yes
P35 Mower motor RPM Yes
P36 Reserved Yes
P37 Mower motor No
P38 Reserved Yes
P39 Reserved Yes
P40 User switches Yes
P41 Rain sensor Yes
P42 Charging pins Yes
P43 Battery (24V) No
P44 Wifi module (ESP8266) Yes
P45 Reserved Yes
P46 Reserved Yes
Motors
Voltages
Protector PCB
Wheel motors wiring
  • steer the robot left/right
Wheel motor features:
  • 24V (load current ~1A)
Motor wiring (left motor):
Wheel motors odometry wiring
Motor (brown)  ---- PCB VCC
Motor (green)  ---- PCB GND
Mower motor wiring
Motor decrease noise
Charger
Total power balance
Battery
schematics
  2. Drive in and out
  3. Tracking and docking
  4. Final version
Bluetooth module
Bluetooth HC-05
Bluetooth HC05 TX  --- PCB RX
Bluetooth HC05 RX  --- PCB TX
Ultrasonic Sensor
An ultrasonic sensor (HC-SR04) allows Ardumower to detect obstacles.
Distance 2 to 450 cm
Wiring
Ultrasonic Module Trigger    — PCB Digital Pin
Ultrasonic Module Echo       — PCB Digital Pin
An internal schematics of the sensor can be found here.[1]
Rain sensor
Using a rain sensor, your Ardumower can stop mowing when it starts to rain. Additionally, it can drive into your charging station.
NOTE: If using YL-83 module, we have no long-term experience regarding corrosion!
Wiring
                    GND o-----o GND Rain sensor module
                    +5V o-----o VCC Rain sensor module
      Ardumower pinRain o-----o D0  Rain sensor module
                                    Rain sensor module IN o----- rain sensor
Photos
  1. Rain sensor test
  2. Simulated rain
  1. Principle schematics
  2. Rain sensor example
GPS
Currently, GPS is used
GPS VCC -- PCB VCC
GPS GND -- PCB GND
GPS TX  -- PCB GPS RX
GPS RX  -- PCB GPS TX
Model R/C
The Ardumower can be controlled via a model R/C. For remote controlling your robot mower you'll need:
  • a model remote control (e.g. 2.4 Ghz)
  • a suitable model remote receiver (4 channels or more)
Wiring
The channel assignment is:
 left stick (left/right):  pinRemoteSwitch
 left stick (up/down):     pinRemoteMow
 right stick (left/right): pinRemoteSteer
 right stick (up/down):    pinRemoteSpeed
  1. demo
WIFI
This is an advanced topic - only use a WIFI module if your Ardumower is fully working. A WIFI module can be used as an alternative for Bluetooth communication. Again, pfodApp is required to connect WIFI and the phone.
https://github.com/FredericG-BE/ardumower/wiki/Using-ESP8266-WIFI-module-on-Ardumower
Realtime clock (RTC)
The robot requires a clock, so that it can start mowing automatically at certain time intervals (timer).
A realtime clock (RTC) returns current time (minute, hour) and date (day of week, day, month, year) - by the help of a battery (Lithium Ion LIR2032, 3.6v, 48 mAh) the time continues to run even if the robot mower is switched off.
Additionally, the RTC module contains an EEPROM memory (non volatile memory) that can hold 4K of permanent user data.
DS1307 module
Troubleshooting "Tiny RTC I2C module"
If your module is losing time/date, fix the circuit like this:
  • Remove D1, R6 and R4
  • Solder jumper wire in place of R6
  • Inspect crystal soldering - fix if necessary
  • Replace battery
Wiring
The RTC module is connected on the I2C bus of the Arduino Mega (in parallel with any other I2C modules).
 DS1307 Module SDA       — Arduino SDA Pin
 DS1307 Module SCL       — Arduino SCL Pin
 DS1307 Module VCC (+5V) — Arduino VCC (+5V)
 DS1307 Module GND       — Arduino GND
Note
If you experience communication problems when using multiple I2C modules on one I2C bus, it is recommended to reduce the length of the cables.
Arduino Dropsensor - Absturzsensor
Funktion:
Der Arduino Dropsensor oder auch Absturzsensor ist dafür gedacht den Mover vor abstürzen vor Treppenabsätzen oder ähnlichen zu schützen. Ebenso kann dieser eingesetzt werden um Inseln von Bäumen und Blumenbeeten zu erkennen. Voraussetzung dafür ist allerdings das dieser an der Graskante hin zur Insel mit einem kleinen Graben umgeben wird damit dieser zuverlässig erkannt werden
Anschluß:
Benötigt werden 2 IR Entfernungssensoren. Am besten sind solche geeignet die bereits in einem externen Gehäuse eingebaut sind. Diese haben auch auf der Rückseite eine Einstellmöglichkeit für die Entfernung bzw Empfindlichkeit. Die Standard Ausführung benötigt 3 Anschlussleitungen . +5V, GND, Signalleitung und haben eine Empfindlichkeit von ca 30mm – 800mm. Bei den Sensor den ich verwende handelt es sich um einen der gegen GND geschaltet wird. Dort habe ich zusätzlich eine Diode in die Signalleitung mit eingebaut um eventuelle positive Spannungen zum Bord zu blockieren und um einen eindeutigen Schaltzustand zu gewährleisten.
ohne eingbaute Diode
IR leuchtet bei Kontakt zur Oberfläche
Messung:
+ nach Signalausgang = 4,96V
- nach Signalausgang = 0V
IR leuchtet nicht über den Abgrund
Messung:
+ nach Signalausgang = 0V
- nach Signalausgang = 3,72V ( das hat mich gestört ) deshalb habe ich die Diode eingebaut
jetzt das ganze mit Diode in der Signalleitung
Messung:
+ nach Signalausgang = 4,7V
Messung:
jetzt 0V gemessen zwischen - und Signalausgang
Ich hatte bedenken gehabt das die 3,72V ein undefinierten Eingang schaffen was evl Probleme bei der Auswertung geben könnte.
Bekannte Probleme:
Ich habe die Beobachtung gemacht das wenn man die Entfernungseinstellung auf den Gras gegebenenfalls noch nach justiert werden muss. Ebenfalls ist mir aufgefallen das wenn die Sensoren auf eine nasse Betonoberfläche stoßen, irrtümlich annehmen das ein Abgrund erkannt wird. Da ich an meinen Testmower die Sensoren nur provisorisch angebracht habe, kann ich mir vorstellen das Fremdlicht zu Problemen in der Erkennung führt. Ich vermute daher, das wenn man die Sensoren vor Fremdlicht schützt, sich die Zuverlässigkeit auch weiter erhöht.
Evl ist es nötig mit Hilfe einer LED die Fläche zu beleuchten um immer eine gleichmäßige Helligkeit zu gewährleisten.
Relay
Using a relay, you can switch on/off external functions (light, horn etc.) on your Ardumower via pfodApp.
Wiring
                      GND o-----o GND Relais module
                      +5V o-----o VCC Relais module
 Ardumower pinUserSwitch1 o-----o IN1 Relais module
                                      Relais module  K1 o-----LED-----o LED supply voltage
                                      Relais module  K1 o-------------o GND
Pictures
