Ardumower's bumper sensor (called 'BumperDuino') is based on a pressure sensor and helps us to detect obstacles.
The PCB module and sensor can be purchased as complete kit via the shop .
Building instructions
Building instructions as well as instructions for programming the Arduino can be found in the BumperDuino manual.
Schematics
Code
You can download the Arduino Code here. Important: Choose 'Arduino Uno' as bootloader.
To upload the code, set jumper to 'VUSB' and connect an USB-TTL adapter to J4 (USB-LIGHT) as follows:
J4 (USB-LIGHT) 1 -- USB-TTL GND 2 -- not used 3 -- USB-TTL +5V 4 -- USB-TTL TX 5 -- USB-TTL RX 6 -- USB-TTL DTR (reset)
All steps are described in more detail here: FT232RL USB-adapter manual.
Connecting to Ardumower
Set jumper to 'VIN', and connect VIN and BUMPER-OC to Ardumower as follows: VIN (+) -- 9-12V (-) -- GND BUMPER-OC DC1 -- Ardumower bumper left/1 DC2 -- Ardumower bumper right/2
