Raindancer Firmware (Deutsch)
- 1 Download
- 2 Überblick
- 5 config.h
- 6 QUICK START TO MOW
- 6.6 Mähmotor Inbetriebnahme
- 6.8 Konfiguration Bluetooth
- 6.10 Erste Testfahrt
- 7 TUNE UP
- 7.2 Charge Service
- 7.3 Watchdog
- 7.5 I2C Bus
- 7.6 RTC
- 7.7 EEPROM
- 7.10 Spiralfahrt
- 7.11 Perimeter Tracking
- 7.12 Schnelle Rückkehr
- 8 Perimeter Sender
- 9 Troubleshooting
- Regensensor einbinden
- SRF08 einbinden
- PCB1.3 mit Arduino DUE
- Original Ardumower Mähmotor
- BT Modul
- 24V Spanungsversorgung
- RTC mit EEPROM
- Durchfahrende Ladestation
clc.v,s Motor stoppen
z //mow motor start
t //mow motor stop
// Orignal Ardumower Bumper Pins #if CONF_DISABLE_BUMPER_SERVICE == false if (( /*diBumperL == LOW &&*/ diBumperR == LOW) && _bumperActivated) { if (flagShowBumper) { errorHandler.setInfo("!03,Bumper deactivated\r\n"); } _bumperActivated = false; //motor.hardStop(); } if ((/*diBumperL == HIGH ||*/ diBumperR == HIGH) && !_bumperActivated) { if (flagShowBumper) { errorHandler.setInfo("!03,Bumper activated\r\n"); } _bumperActivated = true; //motor.hardStop(); } #endif
// Orignal Ardumower Bumper Pins #if CONF_DISABLE_BUMPER_SERVICE == false if (( /*diBumperL == HIGH &&*/ diBumperR == HIGH) && _bumperActivated) { if (flagShowBumper) { errorHandler.setInfo("!03,Bumper deactivated\r\n"); } _bumperActivated = false; //motor.hardStop(); } if ((/*diBumperL == LOW ||*/ diBumperR == LOW && !_bumperActivated) { if (flagShowBumper) { errorHandler.setInfo("!03,Bumper activated\r\n"); } _bumperActivated = true; //motor.hardStop(); } #endif
// Orignal Ardumower Bumper Pins #if CONF_DISABLE_BUMPER_SERVICE == false if (( diBumperL == HIGH && diBumperR == HIGH) && _bumperActivated) { if (flagShowBumper) { errorHandler.setInfo("!03,Bumper deactivated\r\n"); } _bumperActivated = false; //motor.hardStop(); } if ((diBumperL == LOW || diBumperR == LOW && !_bumperActivated) { if (flagShowBumper) { errorHandler.setInfo("!03,Bumper activated\r\n"); } _bumperActivated = true; //motor.hardStop(); } #endif
Spiralfahrt
if(GETTB(TB_ACTVATE_AUTO_SPIRAL)) { (a) if(bb.mowMotorSensor.motorUnderHeavyLoad) { if(millis()-bb.lastTimeSpiralStarted > 15000ul) { bb.flagCruiseSpiral = true; } } (b) if( (millis()-bb.lastTimeSpiralStarted > 180000ul) && bb.mowMotorSensor.checkIfUnderLoad() ) { // Alle 3 Minuten Spirale starten wenn motor belastet bb.flagCruiseSpiral = true; } }
if ((millis() - lastTransitionTime) > 1000) { // If more than 1sec inside rotate aggressive bb.motor.L->setSpeed((bb.cruiseSpeed + 10)); bb.motor.R->setSpeed(-25); }
if ((millis() - lastTransitionTime) > 1800) { bb.cruiseSpeed = 25; bb.driveDirection = DD_ROTATECW; bb.motor.L->setSpeed(25); bb.motor.R->setSpeed(-25);
if ((millis() - lastTransitionTime) > 1000) { // If more than 2sec Outside rotate aggressive bb.motor.L->setSpeed((bb.cruiseSpeed + Output)); bb.motor.R->setSpeed((bb.cruiseSpeed +5)); }
if ((millis() - lastTransitionTime) > 1500) { // If more than 2.8sec Outside rotate more aggressive bb.motor.L->setSpeed((bb.cruiseSpeed + Output)); bb.motor.R->setSpeed((bb.cruiseSpeed +10)); }
if ((millis() - lastTransitionTime) > 1500) { // If more than 2.8sec Outside rotate more aggressive bb.motor.L->setSpeed((bb.cruiseSpeed + Output)); bb.motor.R->setSpeed((bb.cruiseSpeed +10)); } if ((millis() - lastTransitionTime) > 2000) { // If more than 3.5sec Outside rotate full bb.cruiseSpeed = 25; bb.driveDirection = DD_ROTATECC; bb.motor.L->setSpeed(-25); bb.motor.R->setSpeed(25); }
if (bb.perimeterSensoren.isLeftOutside() == true) { bb.cruiseSpeed = 25; bb.driveDirection = DD_ROTATECC; bb.motor.L->setSpeed(-25); bb.motor.R->setSpeed(25); waitForRightInside = true; }
Schnelle Rückkehr
virtual NodeStatus onUpdate(Blackboard& bb) { ...
//============================================ // Calculate driven angle every 500ms. //============================================ if (millis() - lastRunAngleCalculation >= 500) { lastRunAngleCalculation = millis(); ... angle = (cmL - cmR) * 57.2957795f / CONF_DISTANCE_BETWEEN_WHEELS_CM; if (flagShowFindTriangleStates) { errorHandler.setInfoNoLog(F("Winkel: %f cmL %f cmR %f\r\n"), angle, cmL, cmR); } }
Abfrage der States
// Check for left curve / right curve / second left curve switch (state) {
case 0: // search for left curve if (angle < -25) { if (flagShowFindTriangleStates) { errorHandler.setInfo(F("!03,s0 set state = 1 Left turn found angle: %f ms: %lu\r\n"), angle, millis()); } bb.motor.startDistanceMeasurementTriangle(); ... state = 1; // Activate triangle searching } break;
case 1: // search for right turn distance = bb.motor.getDistanceInCMForTriangle(); if (distance > 55) { state = 0; if (flagShowFindTriangleStates) { errorHandler.setInfo(F("!03,s1 set state = 0 distance %f > 55 ms: %lu\r\n"), distance, millis()); } } else if (angle > 50) { if (flagShowFindTriangleStates) { errorHandler.setInfo(F("!03,s1 set state = 2 angle %f distance %f < 50\r\n"), angle, distance); } bb.motor.startDistanceMeasurementTriangle(); ... state = 2; } break;
case 2: // search for second left curve distance = bb.motor.getDistanceInCMForTriangle(); if (distance > 50) { state = 0; if (flagShowFindTriangleStates) { errorHandler.setInfo(F("!03,s2 set state = 0 distance %f > 50 ms: %lu\r\n"), distance, millis()); } } else if (angle < -25) { if (flagShowFindTriangleStates) { errorHandler.setInfo(F("!03,s2 set state = 3 angle %f distance %f < -25\r\n"), angle, distance); } bb.motor.startDistanceMeasurementTriangle(); ... state = 3; } break;
case 3: if (flagShowFindTriangleStates) { errorHandler.setInfo(F("!03,s3 set state=0 Cross Lawn Activated\r\n")); } state = 0; return BH_SUCCESS; break;
... } return BH_RUNNING; }
Mähzonen können eingerichtet werden, zwischen aneinander liegenden Flächen die eine direkte Verbindung haben. Dazu wird das Perimeterkabel zwischen den Flächen in einem Abstand von ca. 13cm verlegt. Es wird eine Lücke von ca. 30cm zu dem gegenüberliegenden Perimeterkabel gelassen. Dadurch ist die Wahrscheinlichkeit geringer, dass der Roboter die andere Fläche anfährt.
Siehe Bild:
area,x //wobei x die der zurückzulegende Weg ist.
Achtung: Man sollte sich genau merken, wo die Kabel für die Mähzonenabgrenzung liegen, für den Fall das der Rasen vertikutiert wird.
Da der Mower erkennt, in welcher Richtung er sich dreht anhand der zuerst rausgefahrenen Spule, ist es wichtig die Ecken nicht im 90 Grad Winkel zu verlegen. In den folgenden Bildern sind zwei Beispiele zu sehen, wie Ecken verlegt werden sollten.
- 1. 12V vorhanden
- 2. 5V vorhanden
