Ardumower Sunray
- 3 Requirements
- 4 Bluetooth BLE module
- 5 PCB1.3 GPS
- 6 RTK base
- 7 RTK rover
- 8 Firmware
- 9 Phone App
- 10 How does it work
- 11 Discussion / forum thread
Demo video: coming soon
- Optimized for Arduino Due
- Arduino Due
- Bluetooth BLE module (CC2540) and a smartphone (Android/iOS)
Install Bluetooth 4.0/BLE module as shown below.
IMPORTANT: Verify the pinout of your BLE module is matching your PCB pinout (shown at the PCB back side)!
PCB1.3 GPS
1. Connect XBee LongRange antenna 2. Connect GPS multifrequency antenna 3. Connect PCB1.3_GPS_GND to simpleRTK2B GND 4. Connect PCB1.3_GPS_5V to simpleRTK2B 5V_IN 5. Connect PCB1.3_GPS_TX to simpleRTK2B TX1 6. Connect PCB1.3_GPS_RX to simpleRTK2B RX1 7. Connect simpleRTK2B IOREF to simpleRTK2B 5V_OUT (to choose signal voltage level 5v)
Firmware
3. Start Arduino IDE, and upload the sketch to your PCB1.3.
1.1. Download Viewer App:
How does it work
- coming soon
- coming soon
