Ardumower Sunray
- 3 Requirements
- 4 Bluetooth BLE module
- 5 PCB1.3 GPS
- 6 RTK base
- 7 RTK rover
- 8 Firmware
- 9 Phone App
- 10 How does it work
- 11 Discussion / forum thread
Demo video: coming soon
- Optimized for Arduino Due
- Arduino Due
- Bluetooth BLE module (CC2540) and a smartphone (Android/iOS)
Install Bluetooth 4.0/BLE module as shown below.
IMPORTANT: Verify the pinout of your BLE module is matching your PCB pinout (shown at the PCB back side)!
PCB1.3 GPS
- Connect XBee LongRange antenna
- Connect GPS multifrequency antenna
- Connect PCB1.3_GPS_GND to simpleRTK2B GND
- Connect PCB1.3_GPS_5V to simpleRTK2B 5V_IN
- Connect PCB1.3_GPS_TX to simpleRTK2B TX1
- Connect PCB1.3_GPS_RX to simpleRTK2B RX1
- Connect simpleRTK2B IOREF to simpleRTK2B 5V_OUT (to choose signal voltage level 5v)
Firmware
3. Start Arduino IDE, and upload the sketch to your PCB1.3.
1.1. Download Viewer App:
How does it work
- coming soon
- coming soon
