Ardumower Sunray
Ardumower Sunray is an alternative Firmware (experimental) for the Ardumower. It uses RTK GPS to localize cm-precise without a perimeter wire. It requires PCB1.3, Arduino Due, ArduSimpleRTK kit and a phone (Android/iOS).
Demo video: coming soon
- Optimized for Arduino Due
- Arduino Due
- Bluetooth BLE UART module (CC2540) and a smartphone (Android/iOS)
9. Choose configuration message 'CFG (Configuration)' and click on 'Send' to make the configuration in the rover persistent.
10. IMPORTANT: Disconnect USB cable from rover module!
Firmware (Arduino Code)
