Ardumower Sunray
WARNING: everything here is already working but in early prototype phase!
Use Azurit Firmware instead if you need a firmware with more features...
Demo video: coming soon
- Optimized for Arduino Due
- Incomplete (Sunray is 'work in progress') - features like 'exclusion areas' and 'obstacle avoidance' are going to be added soon.
- Experimental (never run your Ardumower unattended with this firmware)
- SimpleRTK2B - starter kit LR IP67 (it's recommended to purchase the RTK-GPS modules via Marotronics as you get them pre-configured for the Ardumower there)
Firmware (Arduino Code)
GPS (invalid, float, fix)
Discussion / forum thread
