Ardumower Sunray
- 6 Bluetooth BLE UART module
- 7 PCB1.3 GPS pin fix
- 8 PCB1.3 odometry divider
- 9 RTK base
- 10 RTK rover
- 13 Phone App
- 14 Odometry test
- 15 RTK GPS test (invalid, float, fix)
- 16 Discussion / questions / forum thread
- 17 How the waypoints are generated
- Demo: Path planning and mowing demo video
- Test: Testing RTK fix robustness (testing RTK fix near walls, buildings)
- Optimized for Arduino Due
- Incomplete (Sunray is 'work in progress') - features like docking, GPS signal-loss detection, obstacle detection and avoidance are going to be added soon.
- Experimental (never run your Ardumower unattended with this firmware)
NOTE: If you purchased your RTK-GPS modules at Marotronics, these modules should be pre-configured and you can skip this section. You can download the ublox F9P config files (with the changes below) here: https://github.com/Ardumower/Sunray.
GPS>XBEE | should blink - your base module is sending satellite reference data to your rover module (via the XBee module) |
XBEE>GPS | should be OFF - your base module should not receive any XBee signal |
GPS FIX | should be ON - your base module has found a valid GPS signal |
NO RTK | should be ON - your base module is not performing RTK (real time kinematic) |
GPS>XBEE | should be OFF - your rover module should not send any XBee signal |
XBEE>GPS | should blink - your rover module is receiving satellite reference data from your base module (via the XBee module) |
GPS FIX | should be ON - your rover module has found a valid GPS signal |
NO RTK | should be OFF - your rover module has found a RTK FLOAT or FIX (is performing real-time kinematic) |
