Ardumower Sunray
- 6 Bluetooth BLE UART module
- 7 PCB1.3 GPS pin fix
- 8 PCB1.3 odometry divider
- 9 RTK base
- 10 RTK external base service
- 11 RTK rover
- 14 Phone App
- 15 Odometry test
- 17 Discussion / questions / forum thread
- 18 How the waypoints are generated
- Optimized for Arduino Due
- Incomplete (Sunray is 'work in progress') - features like docking, GPS signal-loss detection, obstacle detection and avoidance are going to be added soon.
- Experimental (never run your Ardumower unattended with this firmware)
This section describes how to use an external Internet-based correction service (NTRIP) instead of your own base station. You will require the WiFi NTRIP Master module for your rover PCB from Marotronics. Follow these steps for the rover PCB:
1. Instead of the XBee module install the WiFi NTRIP Master module on your rover PCB.
4. Configure your preferred NTRIP service provider, and through which WiFi network should it connect to internet.
5. Save configuration and reset the system. From now on, every time the WiFi hotspot you configured is in range, ArduSimple’s WiFi NTRIP Master will connect autonomously and provide RTK corrections to simpleRTK2B.
6. Connect the rover PCB via USB to your PC, and make sure NMEA GGA message is active on UART2 at 115'200bps. Some NTRIP service providers need this NMEA message to compute a virtal base station based on the estimate fix position.
NOTE: If you purchased your RTK-GPS modules at Marotronics, these modules should be pre-configured and you can skip this section. You can download the ublox F9P config files (with the changes below) here: https://github.com/Ardumower/Sunray.
invalid | no DGPS solution was found |
float | DGPS solution was found but it is ambiguous and therefore not precise. |
fix | DGPS solution was found and it is cm-precise - position has been tracked in realtime (RTK) |
age | The age (in seconds) of the DGPS correction data (sent via the XBee module) |
GPS>XBEE | should blink - your base module is sending satellite reference data to your rover module (via the XBee module) |
XBEE>GPS | should be OFF - your base module should not receive any XBee signal |
GPS FIX | should be ON - your base module has found a valid GPS signal |
NO RTK | should be ON - your base module is not performing RTK (real time kinematic) |
GPS>XBEE | should be OFF - your rover module should not send any XBee signal |
XBEE>GPS | should blink - your rover module is receiving satellite reference data from your base module (via the XBee module) |
GPS FIX | should be ON - your rover module has found a valid GPS signal |
NO RTK | should be OFF - your rover module has found a RTK FLOAT or FIX (is performing real-time kinematic) |
