Ardumower Sunray
- 6 Bluetooth BLE UART module
- 7 PCB1.3 GPS pin fix
- 8 PCB1.3 odometry divider
- 9 Method 1: Your own RTK base
- 10 Method 2: Using an RTK external base service (Internet-based)
- 11 RTK rover
- 14 Phone App
- 15 Odometry test
- 17 Discussion / questions / forum thread
- 18 How the waypoints are generated
- Optimized for Arduino Due
- Incomplete (Sunray is 'work in progress') - features like docking, GPS signal-loss detection, obstacle detection and avoidance are going to be added soon.
- Experimental (never run your Ardumower unattended with this firmware)
6. Connect the rover PCB via USB to your PC, and make sure NMEA GGA message (F0-00 NMEA GxGGA) is active on UART2 at 115'200bps and NMEA is activated for UART2 protocol out. Some NTRIP service providers need this NMEA message to compute a virtual base station (VRS) based on the initial estimated GPS fix position.
NOTE: If you purchased your RTK-GPS modules at Marotronics, these modules should be pre-configured and you can skip this section. You can download the ublox F9P config files (with the changes below) here: https://github.com/Ardumower/Sunray.
invalid | no DGPS solution was found |
float | DGPS solution was found but it is ambiguous and therefore not precise. |
fix | DGPS solution was found and it is cm-precise - position has been tracked in realtime (RTK) |
age | The age (in seconds) of the DGPS correction data (sent via the XBee module) |
GPS>XBEE | should blink - your base module is sending satellite reference data to your rover module (via the XBee module) |
XBEE>GPS | should be OFF - your base module should not receive any XBee signal |
GPS FIX | should be ON - your base module has found a valid GPS signal |
NO RTK | should be ON - your base module is not performing RTK (real time kinematic) |
GPS>XBEE | should be OFF - your rover module should not send any XBee signal |
XBEE>GPS | should blink - your rover module is receiving satellite reference data from your base module (via the XBee module) |
GPS FIX | should be ON - your rover module has found a valid GPS signal |
NO RTK | should be OFF - your rover module has found a RTK FLOAT or FIX (is performing real-time kinematic) |
