Ardumower Sunray
NOTE: This is software is still in EXPERIMENTAL state!
- 6 Bluetooth BLE UART module
- 7 PCB1.3 GPS pin fix
- 8 PCB1.3 odometry divider
- 9 RTK base
- 10 RTK rover
- 13 Phone App
- 15 Odometry test
- 17 RTK float-to-fix recovery and false-fix issues
- 21 IMU, sensor fusion
- 24 How the waypoints are generated
- 25 How the path finding works
- 26 How the obstacle avoidance works
- 27 How the line tracking works
- 28 What data is transferred to the Arduino
- 29 What are the differences between the Ardumower and ArduSimple ublox receiver configurations
- 30 Discussion / questions / forum thread
These are the hardware requirements to add RTK-GPS to your Ardumower. You can purchase the required hardware from Marotronics .
- Optimized for Arduino Due
- Incomplete (Sunray is 'work in progress') - features like docking, GPS signal-loss detection, obstacle detection and avoidance are going to be added soon.
- Experimental: everything you see in the videos is already working but in early prototype phase (never run your Ardumower unattended with this firmware)!
1001: L1-only RTK observables 1002: Extended L1-only RTK observables 1003: Compact L1&L2 observables 1004: Extended L1&L2 observables
--> 1005: Stationary RTK reference station ARP 1006: Stationary RTK reference station ARP with height 1007: Antenna descriptor *1008: Antenna descriptor and serial number
1009: L1-only GLONASS observables 1010: Extended L1-only GLONASS observables 1011: GLONASS basic RTK L1&L2 1012: GLONASS extended RTK L1&L2 *1013: System parameters *1019: GPS ephemeris data *1020: GLONASS ephemeris data *1021: Helmert/Abridged Molodenski Transformation Parameters *1023: Residuals, Ellipoidal Grid Representation *1025: Projection Parameters, Projection Types other than Lambert Conic Conformal *1032: Physical Reference Station Position 1033: Receiver and antenna descriptors
*1073: GPS MSM3 *1083: GLONASS MSM3 *1093: GALILEO MSM3 *1123: Beidou MSM3
1075: GPS MSM5 1085: GLONASS MSM5 1095: GALILEO MSM5 1125: Beidou MSM5
1077: GPS MSM7 1087: GLONASS MSM7 1097: GALILEO MSM7 1127: Beidou MSM7
GPS G1,G2,G3,... L1C/A L2CL L2CM GLONASS R1,R2,R3,... L1OF L2OF GALILEO E1,E2,E3,... E1C E5BQ Beidou B1,B2,B3,... B1D1
invalid | no DGPS solution was found |
float | DGPS solution was found but it is ambiguous and therefore not precise (average error ~20cm). |
fix | DGPS solution was found and it is cm-precise - position is tracked in realtime (RTK) |
age | The age (in seconds) of the DGPS correction data sent from base |
relative: the rover coordinates are always relative to the base antenna absolute: the rover coordinates are computed as relative to some specified (e.g. your base antennna or house) world coordinate (see image below)
GPS>XBEE | should blink - your base module is sending satellite reference data to your rover module (via the XBee module) |
XBEE>GPS | should be OFF - your base module should not receive any XBee/reference signal |
GPS FIX | should blink - your base module has found a valid GPS signal |
NO RTK | should be ON - your base module is not performing RTK (real time kinematic) |
GPS>XBEE | should be OFF - your rover module should not send any XBee signal |
XBEE>GPS | should blink - your rover module is receiving satellite reference data from your base module (via the XBee module) |
GPS FIX | should blink - your rover module has found a valid GPS signal |
NO RTK | should be OFF - your rover module has found a RTK FLOAT or FIX (is performing real-time kinematic) |
Min SV Elevation: 10 [deg] C/N0 Threshold : 0 [#SVs] 0 [dbHz]
Min SV Elevation: 10 [deg] C/N0 Threshold : 10 [#SVs] 30 [dbHz]
For your first NTRIP tests (or even as permanent installation), you might use a portable 4G/WiFi router. Such 4G modem could be used where the WiFi coverage is limited. In addition, you can operate multiple WiFi devices (Ardumower PCB WiFi module, NTRIP client WiFi module, ESP32-CAM WiFi module etc.) via this portable 4G WiFi router.
A Stanley controller is used to precisely track the lines between the waypoints:
additional activated messages for UART1+USB: MSG (messages) 01-07 UBX-NAV-PVT 01-12 UBX-NAV-VELNED 01-14 UBX-NAV-HPPOSLLH 01-3C NAV-RELPOSNED 02-32 RXM-RTCM additional activated messages for UART2+USB: MSG (messages) F0-00 F0-00 NMEA GxGGA RATE (rates) measurement period: 200ms (5 Hz) PRT (ports) baudrate UART1: 115200 baudrate UART2: 115200 protocol out UART2: NMEA protocol in UART2: RTCM3 NAV5 (navigation 5) input filter: #SVs: 10, dbHz: 30
