Ardumower Sunray
NOTE: This RTK mower project is still in EXPERIMENTAL state!
- 6 Bluetooth BLE UART module
- 7 PCB1.3 GPS pin fix
- 8 PCB1.3 odometry divider
- 9 RTK base
- 10 RTK rover
- 13 Phone App
- 15 Odometry test
- 17 RTK float-to-fix recovery and false-fix issues
- 21 IMU, sensor fusion
- 24 How the waypoints are generated
- 25 How the path finding works
- 26 How the obstacle avoidance works
- 27 How the line tracking works
- 28 What data is transferred to the Arduino
- 29 What are the differences between the Ardumower and ArduSimple ublox receiver configurations
- 30 Discussion / questions / forum thread
These are the hardware requirements to add RTK-GPS to your Ardumower. You can purchase the required hardware from Marotronics .
- Optimized for Arduino Due
- Incomplete (Sunray is 'work in progress') - features like docking, GPS signal-loss detection, mowing zones, improved path planning, obstacle detection and avoidance are going to be added later...
- Experimental: everything you see in the videos is already working but in early prototype phase (never run your Ardumower unattended with this firmware)!
1001: L1-only RTK observables 1002: Extended L1-only RTK observables 1003: Compact L1&L2 observables 1004: Extended L1&L2 observables
--> 1005: Stationary RTK reference station ARP 1006: Stationary RTK reference station ARP with height 1007: Antenna descriptor *1008: Antenna descriptor and serial number
1009: L1-only GLONASS observables 1010: Extended L1-only GLONASS observables 1011: GLONASS basic RTK L1&L2 1012: GLONASS extended RTK L1&L2 *1013: System parameters *1019: GPS ephemeris data *1020: GLONASS ephemeris data *1021: Helmert/Abridged Molodenski Transformation Parameters *1023: Residuals, Ellipoidal Grid Representation *1025: Projection Parameters, Projection Types other than Lambert Conic Conformal *1032: Physical Reference Station Position 1033: Receiver and antenna descriptors
*1073: GPS MSM3 *1083: GLONASS MSM3 *1093: GALILEO MSM3 *1123: Beidou MSM3
1075: GPS MSM5 1085: GLONASS MSM5 1095: GALILEO MSM5 1125: Beidou MSM5
1077: GPS MSM7 1087: GLONASS MSM7 1097: GALILEO MSM7 1127: Beidou MSM7
GPS G1,G2,G3,... L1C/A L2CL L2CM GLONASS R1,R2,R3,... L1OF L2OF GALILEO E1,E2,E3,... E1C E5BQ Beidou B1,B2,B3,... B1D1
invalid | no DGPS solution was found |
float | DGPS solution was found but it is ambiguous and therefore not precise (average error ~20cm). |
fix | DGPS solution was found and it is cm-precise - position is tracked in realtime (RTK) |
age | The age (in seconds) of the DGPS correction data sent from base |
relative: the rover coordinates are always relative to the base antenna absolute: the rover coordinates are computed as relative to some specified (e.g. your base antennna or house) world coordinate (see image below)
GPS>XBEE | should blink - your base module is sending satellite reference data to your rover module (via the XBee module) |
XBEE>GPS | should be OFF - your base module should not receive any XBee/reference signal |
GPS FIX | should blink - your base module has found a valid GPS signal |
NO RTK | should be ON - your base module is not performing RTK (real time kinematic) |
GPS>XBEE | should be OFF - your rover module should not send any XBee signal |
XBEE>GPS | should blink - your rover module is receiving satellite reference data from your base module (via the XBee module) |
GPS FIX | should blink - your rover module has found a valid GPS signal |
NO RTK | should be OFF - your rover module has found a RTK FLOAT or FIX (is performing real-time kinematic) |
Min SV Elevation: 10 [deg] C/N0 Threshold : 0 [#SVs] 0 [dbHz]
Min SV Elevation: 10 [deg] C/N0 Threshold : 10 [#SVs] 30 [dbHz]
Tip: If you experience IMU recoveries (shown under statistics in the App), it is recommended to add additional 4.7K pull-up resistors to the SCL and SDA lines:
1. Add 4.7K resistor between IMU pins SCL and AD0
2. Add 4.7K resistor between IMU pins SDA and AD0
A Stanley controller is used to precisely track the lines between the waypoints:
additional activated messages for UART1+USB: MSG (messages) 01-07 UBX-NAV-PVT 01-12 UBX-NAV-VELNED 01-14 UBX-NAV-HPPOSLLH 01-3C NAV-RELPOSNED 02-32 RXM-RTCM additional activated messages for UART2+USB: MSG (messages) F0-00 F0-00 NMEA GxGGA RATE (rates) measurement period: 200ms (5 Hz) PRT (ports) baudrate UART1: 115200 baudrate UART2: 115200 protocol out UART2: NMEA protocol in UART2: RTCM3 NAV5 (navigation 5) input filter: #SVs: 10, dbHz: 30
