AzuritBer Firmware (English)
What is AzuritBer and Why
Level 1 Standard
Level 2 Raspberry
It's Level 1 but now:
It's level 2 but now:
First start Level 1
are set like that.
Odometry Setting
Value 1
Go To : Main Menu / Test ODO
Use 1 turn Wheel FWD
Value 2
Value 3
Mower need to rotate according your choice.
Motor Setting
Many Values are require and need to be set in correct order:
Value 1
Here you can adjust the RPM max speed and PWM max speed
First set the POWER MAX
PWM is use into automatic mode and need to be enought for the mower to reach the RPM max value.
If the wheel don't roll smoothly in manual forward ,you need to adjust the RPM_P RPM_I and RPM_D
