Level 2 Raspberry Pi
What you need
1 DC/DC voltage regulator to power the PI.Minumum 5A version from marotronics https://www.marotronics.de/5A-DC-DC-step-down-module-XL4015-with-heat-sink-eg-for-Arduino
Build the SD Card
PI Initial boot with Desktop
Connect everything on the PI.
USB Dongle for mouse. HDMI cable from PI to TV or monitor.
