Chassis 2021
Version vom 6. September 2021, 21:03 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Maintenance & Repair Tips)
Related pages:
  1. Ardumower Tutorials Chassis 2021 Teil 1 WasGehoertDazu
  2. Ardumower Tutorials Chassis 2021 Teil 2 Vorbereitung
  3. Ardumower Tutorials Chassis 2021 Teil 3 Montage
Tools
  • Screw driver
  • Different Torx screw driver
  • Knife
  • Round and flat file
  • sand paper or sand sponge
Whats inside the Box?
Front-Plate
Mow-Plate
Wiring
Case assembly
Motor bearing is stiff
Replace motor bearing by a new one:
mower motor bearing type: 608-ZZ (22mm diameter, 7mm width, 8mm hole)
instructions on ardumower forum
