Perimeter wire
Version vom 29. November 2014, 14:28 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Perimeter v2 (for SVN version, recommended))
So, here's the sender:
Functional test
Receiver
Principle:
'Arduino sound sensor'
LM386 amplifier
Functional test
Choice for coil
Arrangement of coils
Layout of the wire
  1. Perimeter stop test
  2. Perimeter tracking test
While crossing the perimeter loop, something interesting happens: the signal changes its polarity, that means negative and positive voltages reverse each other. By using this principle, crossing the perimeter wire as well as the current state (robot is inside/outside) can be detected. As with perimeter v1, we will again use a motor driver to amplify the signal and an operational amplifier to amplify the received signal. The perimeter sender outputs a digital code (aka 'pseudo-noise' code), and the receiver will detect that code using a software-based digital matched filter. Depending on wheter the match result peak is positive or negative, the robot is inside or outside of the perimeter wire.
Principle:
Bit modulation
The sender signal always toggles between LOW and HIGH (LOW, HIGH, LOW, HIGH, LOW etc.). The next transmitted bit (logical 0 or 1) defines the width of the next pulse.
4.8 Khz (logical 0: single pulse width)
2.4 Khz (logical 1: double pulse width)
So, these are the different cases during signal transmission:
LO, HI encodes 0, 0
LO, HI, HI encodes 0, 1
LO, LO, HI encodes  1, 0
LO, LO, HI, HI encodes  1, 1
Simulation
You can see how it works:
sender circuit:
               |---------o-- GND
               |---------o-- Arduino +5V
Sender current control
Sender automatic standby
Sender software
Sender diagnostics
Receiver
receiver circuit:
Receiver ADC calibration
Receiver diagnostics
sig:  coil signal
mag:  filter result: inside (negative) or outside (positive), strengh: distance to perimeter wire - this is used for perimeter tracking
  1. Perimeter2 demo
  2. 120m perimeter wire test
