Perimeter wire
Version vom 15. Dezember 2014, 14:19 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Perimeter v2 (for SVN version, recommended))
So, here's the sender:
Functional test
Receiver
Principle:
'Arduino sound sensor'
LM386 amplifier
Functional test
Choice for coil
Arrangement of coils
Layout of the wire
  1. Perimeter stop test
  2. Perimeter tracking test
Principle:
Bit modulation
The sender signal always toggles between LOW and HIGH (LOW, HIGH, LOW, HIGH, LOW etc.). The next transmitted bit (logical 0 or 1) defines the width of the next pulse (=one half wave). So, let's call this modulation 'half-wave pulse-width modulation'.
4.8 Khz (logical 0: single pulse width)
2.4 Khz (logical 1: double pulse width)
So, these are the different cases during signal transmission:
LO, HI encodes 0, 0
LO, HI, HI encodes 0, 1
LO, LO, HI encodes  1, 0
LO, LO, HI, HI encodes  1, 1
Simulation
You can see how it works:
sender circuit:
               |---------o-- GND
               |---------o-- Arduino +5V
Sender current control
Sender automatic standby
Sender software
Sender diagnostics
Receiver
receiver circuit:
Receiver ADC calibration
Receiver diagnostics
sig:  coil signal (raw pulse sequence after ADC)
mag:  filter result: inside (negative) or outside (positive), magnitude: distance to perimeter wire (RSSI)
  1. Perimeter2 demo
  2. 120m perimeter wire test
