Perimeter wire
So, here's the sender:
Functional test
Receiver
Principle:
'Arduino sound sensor'
LM386 amplifier
Functional test
Choice for coil
Arrangement of coils
Layout of the wire
- Perimeter stop test
- Perimeter tracking test
Principle:
Signal
The sender sends a repeating sequence of a digital code at 9615 Hz ('pseudonoise4_pw'):
'1' means signal a positive edge, '-1' a negative edge. Because the shortest signal change generated is '-1,1', the lowest generated 'tone' (if you would make this hearable) is 2404 Khz. The longest signal change generated is '1,1,-1,-1', and that generated 'tone' is 4808 Khz.
The coil only sees 'changes' of this signal - so the received signal is:
Simulation
You can see how it works:
sender circuit:
motor driver Vin o-- 12V
|---------o-- GND
|---------o-- Arduino +5V
Sender current control
Sender automatic standby
Sender software
Sender diagnostics
Receiver
receiver circuit:
LM386 IN o------- capacitor 4.7nF ----------- coil 100 mH
Receiver ADC calibration
Receiver diagnostics
sig: coil signal (raw pulse sequence after ADC)
mag: filter result: inside (negative) or outside (positive), magnitude: distance to perimeter wire (RSSI)
Additionally, you can connect the coil to an oscilloscope to to see the sender signal.
