Perimeter wire
Version vom 21. Januar 2015, 05:49 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Perimeter v2 (for SVN version, recommended))
So, here's the sender:
Functional test
Receiver
Principle:
'Arduino sound sensor'
LM386 amplifier
Functional test
Choice for coil
Arrangement of coils
Layout of the wire
  1. Perimeter stop test
  2. Perimeter tracking test
Principle:
Signal
The sender sends a repeating sequence of a digital code ('pseudonoise4_pw') at 9615 Hz :
The coil only sees 'changes' of the sender signal - so the received signal is:
The receiving Arduino ADC samples the signal at 19.2 kHz (because ADC sampling requires at least twice the sender sample rate).
Filter
The signal chosen has specific characteristic: it does not correlate in parts with itself (because it looks 'random'). Because of this characteristic, the signal can be detected by a matched filter (aka 'correlation' with the search signal) and generates a high peak in the matched filter result. The polarity of the peak (positive or negative) determines if the coil is inside or outside of the perimeter wire.
You can see how it works:
sender circuit:
               |---------o-- GND
               |---------o-- Arduino +5V
Sender current control
Sender automatic standby
Sender software
Sender diagnostics
Video explaining all steps
Receiver
receiver circuit:
Receiver ADC calibration
Receiver diagnostics
sig:  coil signal (raw pulse sequence after ADC)
mag:  filter result: inside (negative) or outside (positive), magnitude: distance to perimeter wire (RSSI)
Additionally, you can connect the coil to an oscilloscope to to see the sender signal.
  1. Perimeter2 demo
  2. 120m perimeter wire test
