Perimeter wire
Version vom 28. Januar 2015, 11:47 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Tracking of perimeter)
So, here's the sender:
Functional test
Receiver
Principle:
'Arduino sound sensor'
LM386 amplifier
Functional test
Choice for coil
Arrangement of coils
Layout of the wire
  1. Perimeter stop test
  2. Perimeter tracking test
Principle:
Signal
The sender sends a repeating sequence of a digital code ('pseudonoise4_pw') at 9615 Hz :
Filter
sender circuit:
               |---------o-- GND
               |---------o-- Arduino +5V
Sender current control
Sender automatic standby
Sender software
Sender diagnostics
Video explaining all steps
Receiver
receiver circuit:
Receiver ADC calibration
Receiver diagnostics
sig:  coil signal (raw pulse sequence after ADC)
mag:  filter result: inside (negative) or outside (positive), magnitude: distance to perimeter wire (RSSI)
qty:  filter quality (how distinguisable inside and outside were in filter result)
  1. Perimeter2 demo
  2. 120m perimeter wire test
Mapping and localization
The perimeter magnetic field could be used as input for a position estimation. However, as both the field map and position is unknown, the algorithm needs to calculate both at the same time. Such algorithms are called 'Simultaneous Localization and Mapping' (SLAM). Here's how it could work:
  1. Particle filter-based SLAM
  2. Rao-Blackwellization: model the robot’s path by sampling and compute the 'landmarks' given the poses
