Perimeter wire
Version vom 28. Januar 2015, 16:09 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Mapping and localization (SLAM))
So, here's the sender:
Functional test
Receiver
Principle:
'Arduino sound sensor'
LM386 amplifier
Functional test
Choice for coil
Arrangement of coils
Layout of the wire
  1. Perimeter stop test
  2. Perimeter tracking test
Principle:
Signal
The sender sends a repeating sequence of a digital code ('pseudonoise4_pw') at 9615 Hz :
Filter
sender circuit:
               |---------o-- GND
               |---------o-- Arduino +5V
Sender current control
Sender automatic standby
Sender software
Sender diagnostics
Video explaining all steps
Receiver
receiver circuit:
Receiver ADC calibration
Receiver diagnostics
sig:  coil signal (raw pulse sequence after ADC)
mag:  filter result: inside (negative) or outside (positive), magnitude: distance to perimeter wire (RSSI)
qty:  filter quality (how distinguisable inside and outside were in filter result)
  1. Perimeter2 demo
  2. 120m perimeter wire test
Input to SLAM algorithm:
  • control values (speed, steering)
  • observation values (speed, heading, magnetic field strength)
Output from SLAM algorithm:
  • magnetic field map (including perimeter border)
  • robot position on that map (x,y,theta)
Example SLAM algorithms:
  • Particle filter-based SLAM plus Rao-Blackwellization: model the robot’s path by sampling and compute the 'landmarks' given the poses
