Ardumower PCB
Needed parts
- Main functions
- 1 x Arduino Mega 2560 (or Arduino Due)
- 1 x DC voltage step-down module
- 1 x dual motor driver module with integrated current sensor (2 wheel motors)
- 2 x current sensor module
- 1 x motor driver module (mower motor)
- Resistors, Capacitors, Fuse
- Perimeter sender (optional)
- 1 x Arduino Nano
- 1 x motor driver module with integrated current sensor
- 1 x Arduino Nano
- 1 x pre-amplifier module
- Capacitors, Receiver coil
- Additional modules
- 1 x ultrasonic sensor module (optional)
- 1 x IMU module (gyro, accel. compass) (optional)
- 1 x realtime clock module (optional)
Schematics
KiCad Files are in the SVN
PCB assembly
- PCB dimensions 241x114mm
- All used modules are available in the Ardumower shop
- Uses the Arduino Mega 2560 (and via adapter the Arduino Due)
More photos to come...
PCB 1.0 prototype, jumpers
D7: SHORT-CIRCUIT
JP6: OPEN
JP5: OPEN |
JP4: OPEN
JP5: CLOSE |
JP9: CLOSE |
JP8: CLOSE
JP9: OPEN |
You have two options:
SVN version download steps:
First-time calibration
Wheel motors
ADC calibration
Diagnostic
- loop()-counts per second
- drive home? (1/0)
- "com" - compass course
- "bat" - Battery voltage
- "chg" - Charging current
Starting the mower
Error counter / error beeps
I2C bus / error beeps
Config files
- config.h (old v9.0.3)
- mower.cpp (SVN version)
pfodApp
