Perimeter wire
So, here's the sender:
Functional test
Receiver
Principle:
'Arduino sound sensor'
LM386 amplifier
Functional test
Choice for coil
Arrangement of coils
Layout of the wire
- Perimeter stop test
- Perimeter tracking test
Principle:
Signal
To receive the perimeter signal everywhere on the lawn, the key is to maximize signal-to-noise ratio (SNR). There are two approaches to maximize SNR:
- increase the signal length
Filter
sender circuit:
motor driver Vin o-- 12V
|---------o-- GND
|---------o-- Arduino +5V
Sender perimeter lawn size
At an operating voltage of 12V, the perimeter wire length should not exceed 450m.
Assuming a circle shape, we get a lawn radius:
So, the maximum lawn area size is:
Sender current control
Sender automatic standby
Sender software
Sender diagnostics
Receiver
receiver circuit:
LM386 IN o------- capacitor 4.7nF ----------- coil 100 mH
Receiver ADC calibration
Receiver diagnostics
sig: coil signal (raw pulse sequence after ADC)
qty: filter quality (how distinguisable inside and outside were in filter result)
