Perimeter wire
Version vom 23. Februar 2015, 12:42 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Sender perimeter lawn size)
Magnetic field calculator
So, here's the sender:
Functional test
Receiver
Principle:
'Arduino sound sensor'
LM386 amplifier
Functional test
Choice for coil
Arrangement of coils
Layout of the wire
  1. Perimeter stop test
  2. Perimeter tracking test
Principle:
Signal
To receive the perimeter signal everywhere on the lawn, the key is to maximize signal-to-noise ratio (SNR). There are two approaches to maximize SNR:
  2. increase the signal length
We use a combination of both. The sender sends a repeating sequence of a digital code ('pseudonoise4_pw') at 9615 Hz :
Filter
sender circuit:
               |---------o-- GND
               |---------o-- Arduino +5V
At an operating voltage of 12V, the perimeter wire length should not exceed 450m.
Sender current control
Sender automatic standby
Sender software
Sender diagnostics
Video explaining all steps
Receiver
receiver circuit:
Receiver ADC calibration
Receiver diagnostics
sig:  coil signal (raw pulse sequence after ADC)
qty:  filter quality (how distinguisable inside and outside were in filter result)
  1. Perimeter2 demo
  2. 120m perimeter wire test
