Perimeter wire
Version vom 14. März 2015, 12:55 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Receiver diagnostics)
Magnetic field calculator
So, here's the sender:
Functional test
Receiver
Principle:
'Arduino sound sensor'
LM386 amplifier
Functional test
Choice for coil
Arrangement of coils
Layout of the wire
  1. Perimeter stop test
  2. Perimeter tracking test
Principle:
Signal
  2. increase the signal length
We use a combination of both. The sender sends a repeating sequence of a digital code ('pseudonoise4_pw') at 9615 Hz :
Filter
sender circuit:
               |---------o-- GND
               |---------o-- Arduino +5V
Sender perimeter lawn size
At an operating voltage of 12V, the perimeter wire length should not exceed 450m.
Sender current control
Sender automatic standby
Sender software
Sender diagnostics
Video explaining all steps
Receiver
receiver circuit:
Receiver ADC calibration
sig:  coil signal (raw pulse sequence after ADC)
qty:  filter quality (filter min/max ratio - how distinguisable inside and outside were in filter result - 1.0 means poor quality)
  1. Perimeter2 demo
  2. 120m perimeter wire test
