Perimeter wire
So, here's the sender:
Functional test
Receiver
Principle:
'Arduino sound sensor'
LM386 amplifier
Functional test
Choice for coil
Arrangement of coils
Layout of the wire
- Perimeter stop test
- Perimeter tracking test
Principle:
Signal
- increase the signal length
Filter
sender circuit:
motor driver Vin o-- 12V
|---------o-- GND
|---------o-- Arduino +5V
Sender perimeter lawn size
At an operating voltage of 12V, the perimeter wire length should not exceed 450m.
Sender current control
Sender automatic standby
Sender software
Sender diagnostics
Receiver
For receiving the signal, we use a coil (100 mH or 150 mH) in upright position (centered at front in robot), connected through a capacitor (4.7nF) to an LM386 operational amplifier (to amplify the received signal). When using the LM386 module, capacitor C3 on the LM386 module should be bypassed (which is needed so that the LM386 generates a signal between 0..5V and not the default range -5V..+5V). The LM386 output pin should be connected to an analog Arduino pin ('pinPerimeterLeft').
receiver circuit:
NOTE: It's recommended to directly mount the coil on the amplifier module. This ensures the 'small signal' of the coil is not distorted by other components (motors, DC/DC converters etc.)
Coil
The inductance of 100 mH and capacity of 4.7 nF results in a resonation frequency of 7341 Hz. The inductance of 150 mH and capacity of 4.7 nF results in a resonation frequency of 5994 Hz.
f0 = 1 / (2 * PI * sqrt(L * C)) = 1 / (2 * PI * sqrt(0.15 H * 0,0000000047 F)) = 5994 Hz
Bandwidth = R / L = 155 Ohm / 0.15 H = 1033 Hz
Receiver ADC calibration
sig: coil signal (raw pulse sequence after ADC)
qty: filter quality (filter min/max ratio - how distinguisable inside and outside were in filter result - 1.0 means poor quality)
The 'mag' plot should be clear: Inside the perimeter loop, the signal should be a negative curve, outside it should be a positive curve. If your 'mag' curve is not clear, try to troubleshoot/optimize:
- Always test using long perimeter wire (20m or longer)
- Verify, your coil is connected correctly at 'pinPerimeterLeft'
- Increase distance between coil and mower motor/DC converter
- Use 12V sender voltage, if 'mag' values are too low
