Perimeter wire
Version vom 7. Oktober 2015, 18:56 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Perimeter v2 (used in latest robot code, recommended))
Magnetic field calculator
Principle:
Signal
  2. increase the signal length
We use a combination of both. The sender sends a repeating sequence of a digital code ('pseudonoise4_pw') at 9615 Hz :
Filter
sender circuit:
 motor driver M1OUT1     o---------- perimeter loop (20-450 meters, > 5 Ohm) --+
 motor driver Vin        o-- 6.5V
               |---------o-- GND
               |---------o-- Arduino +5V
Sender perimeter lawn size
area = PI * (r*r) = PI * (18m * 18m) = 1000 m2
Sender current control
  • DC/DC Voltage: The motor driver supply voltage can be changed (6.5-12V via the potentiometer on the DC converter). That's one way to do it and it's the recommended way. NOTE: The minimum voltage (Vin) for the MC33926 motor driver is 5v. If the voltage is lower, the motor driver shuts down sporadically (undervoltage detection-Arduino LED starts to flash).
  • Normal amplitude: Instead of switching the perimter wire between +Vin and -Vin (double amplitude/default), the motor driver can switch it between +Vin and GND (normal amplitude). This will reduce current. To use normal amplitude, comment out the corresponding code line in 'sender.ino':
  • Power resistor: If your perimeter wire resistance (R) is below 5 Ohms, you will not be able to further reduce voltage below 6.5v (otherwise the Arduino will not work properly). Then you have to increase the perimeter wire resistance (R) by using a power resistor (example: 5 ohm, 10W) in series with your perimeter wire.
@6 volts (Vin): 5 ohm power resistor => I=U/R=6v/5ohm=1.2A   (P=U*I=6v*1.2A=7.2W)
MCP4151-5K version:
Vout = 1.23V*(1+VR1/R1)
Using VR1=5K...
Sender automatic standby
Sender software
Sender diagnostics
Video explaining all steps
Receiver
receiver circuit:
* Coil to gear motor: > 15cm
* Coil to mower motor: > 10cm
Signal measurements
Coil and noise measurements
Receiver ADC calibration
  • Adjust voltage of sender: increase voltage (sender DC converter potentiometer) for for longer perimeter (>80m), decrease (sender potentiometer) for shorter perimeter (>25m)
Broken perimeter wire
  1. Using a metal plate, plug one wire of the perimeter sender output into earth ground
  2. Increase your sender voltage to 28 Volts
  3. Connect the LM386 amplifier signal output (signal and GND) to your PC's microphone input
  4. Launch the Web oscilloscope, and switch into frequency view
  6. Now start at the side of the perimeter wire (the side that is still connected to the perimeter wire), and walk along the perimeter wire - the peak frequency of 3.2 Khz should still be there
  7. At the location where the wire is broken, the 3.2 Khz frequency is gone!
Measurements
Noise (max): smag=192
Signal (min): smag=254
SNR=Signal/Noise=254/192=1.3
Signal (min): smag=896
SNR=Signal/Noise=896/192=4.6
  1. Perimeter2 demo
  2. 120m perimeter wire test
  4. Sender PCB
So, here's the sender:
Functional test
Receiver
Principle:
'Arduino sound sensor'
LM386 amplifier
Functional test
Choice for coil
l = coil length
D = coil diameter
Arrangement of coils
Layout of the wire
  1. Perimeter stop test
  2. Perimeter tracking test
