Ardumower PCB
Needed modules
All modules can be purchased as complete kits via the shop .
What is needed for the assembly of Ardumower
- Important modules to choose:
- Zubehör Set (Widerstände, Stiftleisten etc.)
- 2 x Protector Board
- 1 x Mega Board 2560 R3
- 1 x INA169 Strom Sensor Board
- 2 x Dual Treiber MC33926
- 3 x DC-DC LM2596 Step-Down Regler
- 1 x Wireless Bluetooth Modul HC-05
- 1 x Real Time Clock I2C DS1307
- 1 x 24 Volt Ladegerät für den Ardumower Akku
- Optional modules:
- Zubehör Set Ladeschaltung (Blei Akkus)
- WIFI Wlan Modul ESP8266 ESP01
- Ultraschallsensoren HC-SR04 (bis zu 3 Stück werden unterstützt)
- Regensensor
- GPS Modul GY-GPS6MV2
- GYRO-80
- Optional modules:
- Gehäuse inklusive 5 passender Schrauben für das PCB
- Anschlussklemmen max.3 (2xSchleife, 1xLadeanschluss)
- Einbaubuchse für Gehäuse 2,5
- Additional accessories depending on needs:
- A charging station is in development and will follow soon.
- PCB dimensions 241x114mm
- Uses the Arduino Mega 2560
PCB building manual
- Schematics
- Photos
- Build instructions
- WorkaRound20150527
- WorkaRound20150530
- Protector board (required for safe-use of motor drivers!)
- based on Arduino Due
- shields for motor controller, perimeter receiver, etc.
- battery-off circuit
PCB jumpers
Feature used | YES | NO | Comment |
D7: DIODE
D7: SHORT-CIRCUIT
External power while charging (recommended: NO) | JP6: CLOSE
JP6: OPEN
Arduino controlled charge relay (recommended: YES) | JP4: CLOSE
JP5: OPEN |
JP4: OPEN
JP5: CLOSE |
Arduino Due (3.3V I/O) | LP0, ..., LP15: OPEN | LP0, ..., LP15: CLOSE | Do not use if using Arduino Mega |
Bluetooth VCC=3.3V | JP8: OPEN
JP9: CLOSE |
JP8: CLOSE
JP9: OPEN |
Bluetooth programming mode | JP2: CLOSE | JP2: OPEN | Use for reprogramming baud rate etc. |
PCB modules
Module | Feature | Pinout | Optional | Comment |
U1 | DC/DC converter (10V) | GND, Vout, Vin, GND | No | |
U2 | Bluetooth (HC-05) | VCC, GND, TXD, RXD, Key, LED | Yes | |
U3 | Current sensor (charging) | VCC, GND, OUT, IP+, IP-5 | Yes | |
U4 | Charge control (LM350T) | AJD, OUT, IN | Yes | |
U5 | Current sensor (charging) | VCC, GND, OUT, IP+, IP-5 | Yes | |
U6 | DC/DC converter (3.3V) | GND, Vout, Vin, GND | No | |
U7 | DC/DC converter (5V) | GND, Vout, Vin, GND | No | |
U8 | Realtime clock (DS1307) | Batt, GND, VCC, SDA, SCL, DS, SQ | Yes | |
U9 | Wifi (ESP8266) | TX, CH_PD, Reset, VCC, GND, GP_IO2, GP_IO0, RX | Yes | |
U10 | Level shifter 5V->3V (Arduino Due) | Yes | ||
U11 | Wifi (ESP8266) | TX, CH_PD, Reset, VCC, GND, GP_IO2, GP_IO0, RX | Yes | alternative mount position |
PCB connectors
Connector | Feature | Pinout | Optional | Comment |
P1 | Sonar center (HC SR-04) | 5V, GND, Trigger, Echo | Yes | |
P2 | Sonar right (HC SR-04) | 5V, GND, Trigger, Echo | Yes | |
P3 | Sonar left (HC SR-04) | 5V, GND, Trigger, Echo | Yes | |
P4 | reserved | Yes | ||
P5 | IMU (gyro,acceleration,compass) (GY-80) | Yes | ||
P6 | Lawn sensor | Yes | ||
P7 | Status LEDs | Yes | ||
P8 | Odometry right | Yes | ||
P9 | Odometry left | Yes | ||
P10 | GPS (GY-NEO6MV2) | Yes | ||
P11 | Bumper | GND, GND, right, left | Yes | |
P12 | Perimeter coil (center or left) | 5V, GND, perimeter | Yes | |
P13 | R/C remote control | 5V, GND, mow, steer, speed, switch | Yes | |
P14 | Measurement points | 5V, GND, (Depending on JP15: 3.3V, 5V or Arduino 3.3V) | Yes | |
P15 | Wheel motor left | M1OUT1, M1OUT2 | No | |
P16 | Optional motor driver input | Yes | Do not connect | |
P17 | Optional motor driver input | Yes | Do not connect | |
P18 | Wheel motor right | M2OUT1, M2OUT2 | No | |
P19 | Tilt sensor | 5V, GND, tilt | Yes | |
P20 | Button (Start/Stop) | No | ||
P21 | Drop sensor right | Yes | ||
P22 | Reserved | Yes | ||
P23 | Reserved | Yes | ||
P24 | Reserved | Yes | ||
P25 | Reserved | Yes | ||
P26 | Reserved | Yes | ||
P27 | Reserved | Yes | ||
P28 | Reserved | Yes | ||
P29 | Reserved | Yes | ||
P30 | Perimeter coil right | Yes | ||
P31 | Drop sensor left | Yes | ||
P32 | GND | Yes | ||
P33 | 5V | Yes | ||
P34 | 3.3V | Yes | ||
P35 | Mower motor RPM | Yes | ||
P36 | Reserved | Yes | ||
P37 | Mower motor | No | ||
P38 | Reserved | Yes | ||
P39 | Reserved | Yes | ||
P40 | User switches | Yes | ||
P41 | Rain sensor | Yes | ||
P42 | Charging pins | Yes | ||
P43 | Battery (24V) | No | ||
P44 | Wifi module (ESP8266) | Yes | ||
P45 | Reserved | Yes | ||
P46 | Reserved | Yes |
You have two options:
Important for Arduino IDE 1.6 or higher: if you see any folders inside the code folder (e.g. 'unused'), please delete them before compilation! Note: Always verify that the pin configuration in your Arduino code (config.h/mower.cpp) matches your actual circuit!
First-time usage
1. Deactive all sensors:
At first deactivate all sensors - In 'mower.cpp' set the robot settings like this: bumperUse = 0; dropUse = 0; rainUse = 0; sonarUse = 0; perimeterUse = 0; lawnSensorUse = 0; imuUse = 0; batMonitor = 0; odometryUse = 0; gpsUse = 0; buttonUse = 1; timerUse = 0;
2. The software offers a serial console mode. Open the serial console in the Arduino IDE (CTRL+SHIFT+M) and set the baudrate to 19200. The motor and sensor values should appear constantly. First let's delete any existing error:
4. Test motors:
Console: press... d for menu 1=test motorsSecurity note: For security reasons, always remove mower blades in your first tests!
Diagnostics/troubleshooting
- loop()-counts per second
- drive home? (1/0)
- "com" - compass course
- "bat" - Battery voltage
- "chg" - Charging current
Error codes and troubleshooting
Starting the mower
Error counter / error beeps
I2C bus / error beeps
