Ardumower Sunray
- 6 Bluetooth BLE UART module
- 7 PCB1.3 GPS pin fix
- 8 PCB1.3 odometry divider
- 9 RTK base
- 10 RTK rover
- 13 Phone App
- 14 Odometry test
- 15 RTK GPS test (invalid, float, fix)
- 16 Discussion / questions / forum thread
- 17 How the waypoints are generated
- Optimized for Arduino Due
