Ardumower Sunray
Version vom 17. Februar 2020, 20:43 Uhr von Alexanderg (Diskussion | Beiträge) (→‎RTK GPS test (invalid, float, fix))
Video.png Click below to watch demo and tutorial videos:
PCB     PCB
  • Optimized for Arduino Due
PCB     PCB
XBEE>GPS should be OFF - your base module should not receive any XBee signal
NO RTK should be OFF - your rover module has found a RTK FIX (is performing real-time kinematic)
600px
