Ardumower Sunray
Video.png Click below to watch demo and tutorial videos:
PCB     PCB
  • Optimized for Arduino Due
PCB     PCB
NOTE: If you purchased your RTK-GPS modules at Marotronics, these modules should be pre-configured and you can skip this section. You can download the ublox F9P config files (with the changes below) here: https://github.com/Ardumower/Sunray.
Age: the age (in seconds) of the DGPS correction data (sent via the XBee module)
XBEE>GPS should be OFF - your base module should not receive any XBee signal
600px
