Ardumower Sunray
- 6 Bluetooth BLE UART module
- 7 PCB1.3 GPS pin fix
- 8 PCB1.3 odometry divider
- 9 Method 1: Your own RTK base
- 10 Method 2: using an RTK external base service (Internet-based)
- 11 RTK rover
- 14 Phone App
- 15 Odometry test
- 17 Discussion / questions / forum thread
- 18 How the waypoints are generated
- Optimized for Arduino Due
This section describes how to use an external Internet-based correction service (NTRIP) instead of your own base station. You will require the WiFi NTRIP Master module for your rover PCB from Marotronics. Follow these steps for the rover PCB:
1. Instead of the XBee module install the WiFi NTRIP Master module on your rover PCB.
4. Configure your preferred NTRIP service provider (Host, port, Mountpoint, Username, password), and through which WiFi network should it connect to internet.
6. Connect the rover PCB via USB to your PC, and make sure NMEA GGA message (F0-00 NMEA GxGGA) is active on UART2 at 115'200bps. Some NTRIP service providers need this NMEA message to compute a virtal base station based on the estimate fix position.
NOTE: If you purchased your RTK-GPS modules at Marotronics, these modules should be pre-configured and you can skip this section. You can download the ublox F9P config files (with the changes below) here: https://github.com/Ardumower/Sunray.
| age | The age (in seconds) of the DGPS correction data (sent via the XBee module) |
| XBEE>GPS | should be OFF - your base module should not receive any XBee signal |
