Ardumower Sunray
Version vom 25. Februar 2020, 08:55 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Significant changes compared to Ardumower's initial firmware (Sunray vs. Azurit))
PCB     PCB
  • Optimized for Arduino Due
  • Warning.png Experimental: everything you see in the videos is already working but in early prototype phase (never run your Ardumower unattended with this firmware)! Warning.png
PCB     PCB
NOTE: If you purchased your RTK-GPS modules at Marotronics, these modules should be pre-configured and you can skip this section. You can download the ublox F9P config files (with the changes below) here: https://github.com/Ardumower/Sunray.
600px
