Ardumower Sunray
Version vom 26. Februar 2020, 12:40 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Discussion / questions / forum thread)
PCB     PCB
  • Optimized for Arduino Due
PCB     PCB
XBee RF modules issues
We experienced that the XBee mid-range modules have a limited bandwidth, activating the RTCM3 messages at highest rate (1 Hz) at the base will not work stable and data corruption occurs at the rover. You can verify this by looking at the rover's MON-COMMS message using u-center:
For the XBee mid-range the following rates have shown to reduce bandwidth and we were able to get a robust FIX all the time:
base ---------------
rate 10 1005: Stationary RTK reference station ARP 1 1074: GPS MSM4 2 1084: GLONASS MSM4 3 1094: GALILEO MSM4 0 1124: Beidou MSM4 2 1230: GLONASS code-phase
600px
