Ardumower Sunray
Version vom 29. Februar 2020, 09:18 Uhr von Alexanderg (Diskussion | Beiträge) (→‎GPS antenna selection guide)
  • Optimized for Arduino Due
PCB     PCB
XBee RF modules issues
We are currently experimenting with different GPS antennas for the rover. The helical and survey antennas seem to perform slightly better than the normal patch antennas. A RTK-FIX solution is hold in challenging environments with them.
Survey GNSS Multiband antenna (IP66):                   40 dB
Lightweight helical antenna for multiband GNSS (IP67):  33 dB
u-blox GNSS Multiband antenna ANN-MB-00:                28 dB
600px
