Ardumower Sunray
- 6 Bluetooth BLE UART module
- 7 PCB1.3 GPS pin fix
- 8 PCB1.3 odometry divider
- 9 RTK base
- 10 RTK rover
- 13 Phone App
- 14 Odometry test
- 16 XBee RF modules issues
- 17 GPS antenna selection guide
- 18 Bluetooth Low Energy (BLE) antenna hack
- 19 Discussion / questions / forum thread
- 20 Recording perimeter polygon and exclusions polygons
- 21 How the waypoints are generated
- Optimized for Arduino Due
We are currently experimenting with different GPS antennas for the rover. The helical and survey antennas seem to perform slightly better than the normal patch antennas. A RTK-FIX solution is obtained more quickly and hold longer in challenging lawn environments with them.
Maybe this is the right hack for you :-) This is how I added an external SMA antenna to my bluetooth module. Happy hacking! :-)
