Ardumower Sunray
Version vom 1. März 2020, 14:27 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Bluetooth Low Energy (BLE) external antenna hack)
  • Optimized for Arduino Due
PCB     PCB
XBee RF modules issues
We are currently experimenting with different GPS antennas for the rover. The helical and survey antennas seem to perform slightly better than the normal patch antennas. A RTK-FIX solution is obtained more quickly and hold longer in challenging lawn environments with them.
Recording perimeter polygon and exclusions polygons
600px
