Ardumower Sunray
- 6 Bluetooth BLE UART module
- 7 PCB1.3 GPS pin fix
- 8 PCB1.3 odometry divider
- 9 RTK base
- 10 RTK rover
- 13 Phone App
- 14 Odometry test
- 16 RTK float-to-fix recovery issues
- 17 XBee RF modules issues
- 18 GPS antenna selection guide
- 19 Bluetooth Low Energy (BLE) external antenna hack
- 20 IMU, sensor fusion
- 21 Recording perimeter polygon and exclusions polygons
- 25 Discussion / questions / forum thread
- Optimized for Arduino Due
Nordrhein Westfalen (SAPOS HEPS): VRS_3_4G_NW Berlin (SAPOS HEPS): VRS_3_2G_BE
6. Connect the rover PCB via USB to your PC, and make sure NMEA protocol out is activated for UART2 out at 115'200bps (configuration view-> message 'PRT (Ports)'). Also make sure NMEA GGA message is active active on UART2 (configuration view->message 'MSG (Messages)'->F0-00 NMEA GxGGA). Some NTRIP service providers need this NMEA message to compute a virtual base station (VRS) based on the initial estimated GPS fix position.
8. If your NTRIP base antenna position is not constant, you have to switch to position source mode 'absolute' in the App (see section App for more details).
9. You can verify the received RTCM3 messages for the individual satellite systems (GPS, GLONASS, etc.) via ublox uCenter. Start the NTRIP client via 'Receiver->NTRIP client...'
Typical messages you should see:
1074: GPS MSM4
1084: GLONASS MSM4
1094: GALILEO MSM4
1124: Beidou MSM4
1230: GLONASS code-phase
Optional: You can install an IMU (MPU6050) like shown below to improve short-term direction measurements (in addition to wheel odometry). NOTE: IMU support has not been tested thoroughly (for a longer duration) yet.
