Ardumower Sunray
- 6 Bluetooth BLE UART module
- 7 PCB1.3 GPS pin fix
- 8 PCB1.3 odometry divider
- 9 RTK base
- 10 RTK rover
- 13 Phone App
- 14 Odometry test
- 16 RTK float-to-fix recovery issues
- 17 XBee RF bandwidth/corruption issues
- 18 GPS antenna selection guide
- 19 Bluetooth Low Energy (BLE) external antenna hack
- 20 IMU, sensor fusion
- 21 Recording perimeter polygon and exclusions polygons
- 25 What are the differences between the Ardumower and ArduSimple ublox receiver configurations
- 26 Discussion / questions / forum thread
- Optimized for Arduino Due
Nordrhein Westfalen (SAPOS HEPS): VRS_3_4G_NW Niedersachsen (SAPOS HEPS): VRS_3_2G_NI Berlin (SAPOS HEPS): VRS_3_2G_BE
5. Use UART0 and 115200 baud.
6. Save configuration and reset the system. From now on, every time the WiFi hotspot you configured is in range, the WiFi NTRIP Master will connect autonomously and provide RTK corrections to your rover PCB.
1074: GPS MSM4
1084: GLONASS MSM4
1094: GALILEO MSM4
1124: Beidou MSM4
1230: GLONASS code-phase
identical
additional activated messages for UART1+USB: 01-12 UBX-NAV-VELNED 01-14 UBX-NAV-HPPOSLLH 01-3C NAV-RELPOSNED 02-32 RXM-RTCM additional activated messages for UART2+USB: F0-00 F0-00 NMEA GxGGA measurement period: 200ms (5 Hz) baudrate UART1: 115200 baudrate UART2: 115200 protocol out UART2: NMEA protocol in UART2: RTCM3
