Ardumower Sunray
Version vom 4. Mai 2020, 17:16 Uhr von Alexanderg (Diskussion | Beiträge) (→‎How can I find out if my NTRIP provider (e.g. SAPOS) properly works and supports the required correction messages)
  • Optimized for Arduino Due
 Baden Württemberg   (SAPOS HEPS): VRS_3_2G_BW
These are the RTCM3 messages you should see and may see(* = not supported by F9P receiver):
    *1001: L1-only RTK observables
    *1002: Extended L1-only RTK observables
    *1003: Compact L1&L2 observables
    *1004: Extended L1&L2 observables
    *1011: GLONASS basic RTK L1&L2
    *1012: GLONASS extended RTK L1&L2
    *1033: Receiver and antenna descriptors
    1074: GPS MSM4
    1084: GLONASS MSM4
    1094: GALILEO MSM4
    1124: Beidou MSM4
    *1075: GPS MSM5
    *1085: GLONASS MSM5
    *1095: GALILEO MSM5
    *1125: Beidou MSM5
    1230: GLONASS code-phase (this message could be missing - then 1033 should be received instead!)
PCB     PCB
01-12 UBX-NAV-VELNED
01-14 UBX-NAV-HPPOSLLH
Optional: You can install an IMU (MPU6050 / MPU9150 / MPU9250 / MPU9255) like shown below to improve short-term direction measurements (in addition to wheel odometry). NOTE: IMU support has not been tested thoroughly (for a longer duration) yet. Make sure to configure the correct module in 'config.h'. For the shop module, choose MPU9255 in 'config.h'. If you IMU was found correctly, you should hear 8 short buzzer beeps at the mower start (automatic gyro calibration).
600px
How the path finding works
600px
600px
identical
  F0-00 F0-00 NMEA GxGGA
measurement period: 200ms (5 Hz)
baudrate UART1: 115200
baudrate UART2: 115200
protocol out UART2: NMEA
protocol in UART2: RTCM3
