Ardumower Sunray
Icons experimental.png NOTE: This RTK mower project is still in EXPERIMENTAL state!
  • Optimized for Arduino Due
PCB     PCB
01-12 UBX-NAV-VELNED
01-14 UBX-NAV-HPPOSLLH
Tip: You can use Google Maps to find out (Lon, Lat) coordinates for your location: https://www.latlong.net/ PCB
Tip: If you experience IMU recoveries (shown under statistics in the App), it is recommended to add additional 4.7K pull-up resistors to the SCL and SDA lines:
6. Add 4.7K resistor between IMU pins SCL and AD0
7. Add 4.7K resistor between IMU pins SDA and AD0
Longer battery operation time
500px
500px
How the path finding works
600px
600px 400px
How the line tracking works
A Stanley controller is used to precisely track the lines between the waypoints:
600px
600px
MSG (messages):
  F5-05 RTCM3.3 1005
  F5-4A RTCM3.3 1074
  F5-54 RTCM3.3 1084
  F5-5E RTCM3.3 1094
  F5-7C RTCM3.3 1124
  F5-E6 RTCM3.3 1230
MSG (messages)
            baudrate UART2: 115200
            protocol out UART2: NMEA
            protocol in UART2: RTCM3
