Ardumower Sunray
Icons experimental.png WARNING!
  • Optimized for Arduino Due
PCB     PCB
01-12 UBX-NAV-VELNED
01-14 UBX-NAV-HPPOSLLH
Tip: You can use Google Maps to find out (Lon, Lat) coordinates for your location: https://www.latlong.net/ PCB
Longer battery operation time
500px
500px
How the path finding works
600px
600px 400px
How the line tracking works
A Stanley controller is used to precisely track the lines between the waypoints:
600px
600px
MSG (messages):
  F5-05 RTCM3.3 1005
  F5-4A RTCM3.3 1074
  F5-54 RTCM3.3 1084
  F5-5E RTCM3.3 1094
  F5-7C RTCM3.3 1124
  F5-E6 RTCM3.3 1230
MSG (messages)
            baudrate UART2: 115200
            protocol out UART2: NMEA
            protocol in UART2: RTCM3
